96 Disco 1 Intermittently Not Going in Reverse
My 96 Disco 1 has just started intermittently not going in reverse. I turn the ignition on/off several times and move the shift lever and it finally shifts to reverse.
Now, the key will not come out of the ignition and the ABS light just came on.
Could this be the starter?
Thanks.
Kurt
Thanks.
Kurt
Trust me, tighten the nut in the gear shift **** and the key will come right out.
Your transmission is not all the way in park so the key will not come out, it looks like its in park, but its not.
Same thing with reverse, you are not actually in reverse, looks like it, but you're not.
The shift cable is out of adjustment, tighten that nut and you will be good to go.
Thanks.
Kurt
Thanks.
Kurt
