'96 Disco Distributorless Ignition System No Spark
Hi all. This is pretty much a part 2 tech help request for our no spark issue. As stated, vehicle is '96 Disco I DIS. After an extensive storage and battery replacement, I am getting no spark. After a few tests, at the suggestion of Disco Mike and Spike555 (thank you both), I realize I apparently do not have a crank angle problem, and the communication between alarm and ECU seems okay. I have power at the injectors and fuel pump operation with pressure around 38. Is there any wiring diagrams available for the '96 DIS as this would be helpful. All diagrams that I have come across show a distributor. If I could obtain information on operation and a wiring diagram, I could figure this out. Any help would be greatly appreciated. Thanks in advance.
I have the Rave. All the diagrams show the distributor - unless for some reason I'm missing the correct one. It's ok, though. I found what I needed on another post showing the coil pack's connection to the ECM and the fuse box. Hopefully it will help me get it going. Thanks Spike555.
can you (or anyone) direct me to thie post referenced above? I cannot find it, and it may be useful for my current problem.
1999SE40
May 16, 2014 09:55 AM
bufaton
Mar 24, 2013 02:02 PM
