97 5spd ques
what transmission fluid do you put in a lr 5spds and the slave value or is it the same for the auto... i am trying get it up and run right since i totally mine 99 disco 1
The owners handbook lists ATF, however Land Rover released a Technical Service Bulletin stating to switch to MTF (Manual Transmission Fluid).
I run Redline MTL in both of mine.
Red Line Synthetic Oil - Gear Oil for Manual Transmissions - MTL 70W80 GL-4 Gear Oil
