air conditioning cuts out
Old 07-16-2010, 04:20 PM
red rover 99's Avatar
Smile air conditioning cuts out
today i noticed while driving my 99 disco I, the air conditioning abruptly shut down. i turned fan off and on again and it restarted. this happened twice today. maybe unrelated but my check engine light was on for 2 days then went out. it was not on when the a/c did it's new trick! temp guage is is normal....
Old 07-16-2010, 04:34 PM
discomedic4's Avatar
Mine has been doing the same thing for months and I haven't been able to figure it out. Mine does appear to be heat related however. Good luck. I will be following this thread closely to see what you find out.
Old 07-16-2010, 07:13 PM
Is your a/c system full of R-134a?
You can check this yourself with a DIY a/c recharge kit.
Old 07-17-2010, 08:24 AM
XCELLER8's Avatar
is the A/c itself quitting or is the fan stopping intermittently ?
Old 07-17-2010, 10:51 AM
thanks! we are in a heatwave here in phila!
will check that! thanks!
Old 07-17-2010, 10:53 AM
good question....i'll pay attention if it happens again.
Old 07-17-2010, 02:49 PM
AK Rover's Avatar
My 97 the fan would cut out at random times on heat or AC. It never happened enough to bother troubleshooting but I was thinking either a loose connection or a failing blower motor.
Try to pay attention to whether you hit a bump or anything out of the ordinary when it happens. That should give a clue to what's causing the problem. If it cuts out after you hit a bump I'd think loose connection somewhere in the system.
Old 07-17-2010, 07:08 PM
Long Haul's Avatar
I would bet its a bad switch on the dash. Mine was doing the same thing and I got mad and broke the switch then I replaced with a new one no problems of it shutting off since
Old 06-15-2015, 06:58 AM
TOM R's Avatar
Old thread same issue
Last few days blower on 4 a/c on
Blower cuts out and a/c light turns off then both come back on, only affects front a/c blower
Bad fan switch?
Quick Reply: air conditioning cuts out
