Alternator problem
Old 09-03-2016 | 07:23 PM
frankh's Avatar
Default Alternator problem
Have a 94 disco. Put in an alternator and it's not working. Checked the belt and it's right. There was a plastic cube wired to the old one. It went from the same place as the tach wire to the alternator body. What part is this and can it be purchased at an auto parts store or have to be ordered. Thanks for helping.
Old 09-03-2016 | 08:16 PM
ihscouts's Avatar
A noise suppressor so you wouldn't hear the whine through the radio and a phase tap resistor which protects the alternator if there is a short. Have you double checked your ground connections to make sure they're nice and clean?
Old 09-03-2016 | 08:32 PM
frankh's Avatar
I will check the grounds in the morning. Thanks.
Old 09-10-2016 | 10:23 PM
Mark G's Avatar
Wait, this isn't the 'old mis-routed serpentine belt issue' is it? Better check that. 80% of people get it wrong I bet and the result is what appears like a non-charging alternator ...and the dash gauges go crazy too. Plus, it prematurely wears the grooves on the alternator pulley making the problem even worse. Do a search and you can read other posts on it. The PO of my vehicle couldn't figure out the electrical problems on mine and just threw up his hands ...took me a while to zero in on it too, but it was a cheap fix. It's so easy to overlook. Good luck.
Old 09-10-2016 | 10:33 PM
ihscouts's Avatar
Originally Posted by frankh
....Checked the belt and it's right.
When someone says they checked it and it's right it's decent to give them the benefit of the doubt. If it isn't then they'll figure it out eventually after a few more alternators have been swapped in, law of averages.......
Old 09-13-2016 | 06:25 AM
frankh's Avatar
Default belt routing
It was not the belt routing. The alternator was bad. Thanks.
JumPeR04
12-17-2009 08:57 PM
mgabriel
12-12-2008 12:53 AM
Mark G
03-19-2008 06:28 AM
discoland
01-05-2008 04:19 PM
jaybe_2
04-03-2007 07:04 PM
