Another Newbie - Timing Cover Leak
Just picked up a decent 99 Discovery I, but it has leak from timing cover. Have downloaded manual and started removal process. Still working on loosening fan, but my question is the oil pan bolts. The manual indicates to remove the front 2 bolts and loosed two more on each side of pan. The trouble is the front 2 bolts on my pan are not bolts, but appear to be studs with bolts holding pan. The cover cannot be removed forward with studs there. Has anyone run across this and is it possible to remove studs without breaking them in block. Or will I actually have to drop the whole oil pan. I was hoping to not have to do this as it is supposedly not required. Anyones experiences or assistance will be greatly appreciated.
Are you sure, it is a D1 and the manual indicates it should be able to be done without the pan removal. Was hoping someone had similar experience and was able to remove studs, but worst case, as you indicate the pan will have to be dropped. Too bad as it adds a lot of work and new gasket and oil change. Thanks for reply.
Gasket's are available but not reccomended
Thanks for info, used the ultra black for pan and permatex 2 for cover gasket. All back together and seems to be holding. But have a radiator leak on left side just below upper transmission connection. Was on a roll, but was told that rad might have a leave. Have tried some stop leak, but sourcing a radiator shipped to Canada. Amazing that I can order one from Houston cheaper than I can get on line from Canada.
