anti lock light on
Old Jan 31, 2015 | 08:00 AM
martin12's Avatar
Default anti lock light on
The anti lock light on the dash is on and doesn't seem to go off less I turn the key off. I tried the blink method by jumping pin 5 and 15, tried using a paperclip and a small wire, neither worked. I don't know if I was supposed to remove anything before I tried the blink method or not. Would like to have abs, only had the vehicle for a few months and the light has been on since I had it. I hooked it up to autel 619 scanner but it said it couldn't retrieve and abs codes. Any help is appreciated thanks.
Old Jan 31, 2015 | 12:32 PM
martin12's Avatar
Anybody got any ideas
Old Jan 31, 2015 | 02:47 PM
OverRover's Avatar
Maybe obvious, but be sure you have the jumper wire in pins #5 & #15 in the OBDII connector in the right place.
That connector is c2083 and it reads upside down. TOP from the LEFT starts at pin #16. BOTTOM from the LEFT starts at pin #8.
Again maybe obvious, but I've seen this mistake made more than a few times.
So, turn the ignition switch to 0 (Off). Install the jumper wire, and then turn the switch to position 2. Cross fingers and count BLINKS.
Good Luck.
Old Jan 31, 2015 | 04:36 PM
martin12's Avatar
Ok sounds good I wasn't sure if the wire had to be inserted before or after turning the key. Do I need to crank the truck or just turn it on.
Old Jan 31, 2015 | 06:15 PM
OverRover's Avatar
" Do I need to crank the truck or just turn it on. "
Just turn the key to position 2 and the dash lights will come on. Then don't touch the key until you get the codes. AND don't forget to cross your fingers, say a prayer, whatever works.
DON'T crank/start the truck.
Old Jan 31, 2015 | 10:10 PM
martin12's Avatar
Ok will give it a shot in the morning. Thanks for the fast response
Old Feb 2, 2015 | 08:55 PM
socal1200r's Avatar
I had the same issue. After failing to get the codes, I did what some others suggested, and pulled the main ABS fuse. However, the ABS light still stayed on, so I removed the bulb. Truck brakes fine, no ABS groaning, no ABS light, all is right with the world again, lol...
Old Feb 4, 2015 | 12:59 PM
archaeology_student's Avatar
Not sure if this has been mentioned but the ABS can be a result of loose ABS sensors.
Sometimes they become slightly dislodged and require re-seating with a tap or removal, a quick cleaning and then re-seating with a new washer ;-)
Old Feb 5, 2015 | 04:12 PM
martin12's Avatar
Well finally got around to trying the blink method again. Starting to drive me crazy. No blink at all, might have flickered a little maybe I was starring at it and imagined it who knows. Tried pulling both fuses under the hood to at least kill the light no luck. I guess wishful thinking on my part. It's the only light on the dash so I figure I should at least clear it then move on to other things. I don't guess if I happened to fix the problem by cleaning the sensors and making sure there pushed all the way in will make the light go out? Is there a reader that will read the 98 abs codes or is that a dealer only thing? Thanks
Old Feb 6, 2015 | 08:20 AM
jimvw57's Avatar
black duct tape...
