Bad Day
Old Jun 6, 2011 | 11:41 PM
bantham1's Avatar
Default Bad Day
Today was a bad day for the D1 and me. The truck broke down in the drive through lane (with wife driving to make maters worse...imagine what I went through!). It seemed as if it was running out of fuel and would not start back up. The truck turns over but will not start. So, I had the tow truck pick it up or I thought that was the case. When I got off work, some crackhead had ripped my dash apart and stole my radio and the tow truck was not there. Now I have to replace the center plastic dash out, replace the radio, and then figure out what is wrong with the truck. I did check the fuel pressure and it did not even register on my gauge, but this was while the truck was not running with key on as it will not start.
Old Jun 7, 2011 | 02:16 AM
moomoo's Avatar
Man I am so sorry to hear that. I am not sure what your no start issue is but it could be a small number of things. What a drag....it has to get better.
Old Jun 7, 2011 | 06:26 AM
bantham1's Avatar
There is no fuel pressure at all. I am thinking fuel pump relay, fuel pump, crank start sensor, or alarm related. Which one is most likely?
Old Jun 7, 2011 | 08:31 AM
turf63's Avatar
Well because it happened under normal operating conditions first you could probably be safe to rule out alarm related right?
Old Jun 7, 2011 | 09:40 AM
jdhuegel1's Avatar
Check the cheap things first...
Voltage/operation of pump (testing is free). If pump is working, your filter might be clogged. Passenger side rear wheel well, at the top.
Old Jun 7, 2011 | 09:51 AM
bantham1's Avatar
I did have a problem with a stumble/rough idle upon start once in a while, especially when hot outside. I do not know if this could be related. No fuel at all in the rail.
Old Jun 7, 2011 | 10:08 AM
DiscoJag's Avatar
See if you can hear the fuel pump running. If it's not, check the fuse, check the relay, check for current at the pump or hook it to a trickle charger and see if it will run. If not, replace the fuel pump. I did mine recently, and it's not that bad of a job. If the fuel pump is running, or even if it's not, replace the fuel filter. If it's been in there a while, it will need it. I pulled mine out and I could not blow through it - not good.
Old Jun 7, 2011 | 10:11 AM
DiscoJag's Avatar
That's nasty about the radio being stolen. Who would break into a D1 to steal the radio ? Mine still works, but the dial doesn't light up at night anymore.
Old Jun 7, 2011 | 10:21 AM
bantham1's Avatar
It is a 1998 D1. Hopefully it is not the pump. The ones I have seen are around 500 for it.
Old Jun 7, 2011 | 10:32 AM
LeakyDisco's Avatar
Have someone try to start the truck while you lightly tap on the pump with a rubber mallet or a good knock with your hands. When mine went, it would keep running for a few seconds if I tapped it.
You can get the pump (assuming you have the AEL fuel system) from AB for less than $400.00. I think I paid $367.00.
Replacing the pump is simple, but check the other stuff first (filter, etc.) before shelling out the money for the pump.
