Big Upgrades
Old Mar 21, 2013 | 09:58 PM
XCELLER8's Avatar
Originally Posted by calebbo
I had the top mount of the shocks still bolted to the chassis but the bottom mounts I just unbolted. I jacked up the axles then I placed jack stands behind where the trailing arms connected to the chassis (more towards the behind-end of the vehicle). Once I lowered the axle I stepped on the hub and compressed the spring. I found if you remove the bottom retaining plate and put that in AFTER you have the spring in place it is MUCH easier. The driver side was a PITA and it looks like the coil went through hell and back but the passenger side went in with little resistance and minor scratch or two. So the lift is installed just waiting on my tires. I guess I can tackle the water pump tomorrow. If I don't have a gasket can I just use a gasket maker or should I source a gasket from somewhere?
get a gasket.....
Old Mar 21, 2013 | 11:08 PM
tweakrover's Avatar
I'm pretty sure it's supposed to be like this
)I~I(*
Reason being the shock leans depending on where the suspension is in travel, the curved washer allows it to flex without the bushing being totally crushed on one side, that bushing will only squish so much before it blows out or the shock bends
Old Mar 22, 2013 | 05:42 AM
calebbo's Avatar
I couldn't really tell from these pictures on RN.
Old Mar 22, 2013 | 07:59 AM
fishEH's Avatar
I had that I just didn't know which way the washer went. It kind of looks like a hamburger bun how it's curved on one end and flat on the other (well relatively flat more like inverted) so I did it like this :
Washer with hamburger curve up/Bushing/Mount/Bushing/Hamburger up/Nut.
LIKE THIS:
( I ~ I ( *
NOT THIS:
( I ~ I ) *
( = washer and direction of curve
I = Bushing
~ = Mount
* = Nut
Like this:
(I~I)*
The washers are designed to cup the bushings.
Old Mar 22, 2013 | 09:54 AM
EricTyrrell's Avatar
Originally Posted by fishEH
Like this:
(I~I)*
True. That is also the stock configuration.
However, the bushings will push the washers inside-out. They're not strong enough.
Old Mar 22, 2013 | 02:36 PM
RacerX's Avatar
Are the stock washers thicker/better such that they could be reused? I ask because 1) I have not messed with mine to know the application specifically and 2) in my other car world (BMW) a well known parts supplier supplies "upgraded" bushings with **** washers that end up bending/failing, the solution is to reuse stock which are very robust.
Cheers.
Old Mar 22, 2013 | 03:06 PM
Some of my stock ones were shredded, others were fine. Still need to talk to AB about this..
Old Mar 22, 2013 | 04:16 PM
fishEH's Avatar
That's a bunch of garbage right there. I'd be on the horn with somebody. What brand shocks?
Old Mar 22, 2013 | 04:27 PM
TF. Just noticed it after inspecting. Pro-sport shocks seem to be holding up well, but the hardware not so much. I'd be on the horn, but I leave the country for two weeks tomorrow.
Old Mar 22, 2013 | 05:33 PM
CUpgt's Avatar
Just convert to eye-eye shocks and dont worry about it
