Body Panels
Pulled up the rear carpet and the damn moisture trap and found quite a bit of serious rust thru on the inside section..Can replacement panels be had ? Basically I need to replace the center section in the rear...
I may grind out all the rust.. Paint it with some rust inhibiting whatever and then lay a piece of plywood on top with some foam in between to seal it all up....It needs to have a nice smooth cargo floor anyway...Plywood was always the plan.. Just didn't plan on the rot...
Anybody sell THESE in the US ?
John
John
Yes you can buy replacement panels.
They sell them in the UK, not sure if they sell them here in the US.
Go to the junk yard and buy a pickup truck box in good shape, cut to fit, weld it in.
Probably be cheaper than ordering from the UK.
Captain Ducman
Dec 18, 2006 07:06 PM
