Bouncing - Tachometer - Nearly Unresponsive
Hi Fellow Rover-neers..
History: When I first got this "New to me" 94/95 Disco day 2 of ownership - I noticed that the Serpentine Belt was warn - So I went to the local AZ and purchased asked for the belt - They gave me the belt - Took it home - I drew the belt pathway as it was on from PO and tried to put the belt on - It was very loose - So I took the PO belt and new belt back - Got a belt from AZ that was the same length and put that belt on based on the pathway I drew - which I thought was the manufacture pathway -
In the process of troubleshooting a water temp issue - I checked the "correct" belt path as found in the TECH sticky - low and behold, the belt path was not correct - So I adjusted the belt and put it back to the correct pathway - The seems to be tight with less then a 1/4 inch movement.
Now the tachometer is bouncing all over the place - It doesn't seem to stay at in one place at one time, but it doesn't seem to stick in one place. Also it doesn't seem to instantly respond if I rev the engine.
I will be looking at the "white" wire connected to the alternator - as this is one suggestion from another post - and it could possibly be loose and/or somehow shorting.
Is this an indication that my alternator is going out?
Are there any other suggestions?
Thanks for your input, in advance...
In Peace and Agape,
Trav...
In Peace and Agape,
Trav...
Chris-bob,
The belt I got "originally" was 1/2 to 3/4 inch longer. When I tried to install it "in the bad pathway" I couldn't get any tension on the belt and the tensioner was "bottomed out". -
Wouldn't this still be the case if I tried to use the same belt?
Should I have more then 1/4 inch of belt play when tensioned up?
In Peace and Agape,
Trav...
In Peace and Agape,
Trav...
Here is what I read;
You got a replacement belt and installed it the same way the old one was.
Belt is now too loose.
You get a new, shorter belt that matches what was on. Fits.
You notice belt is routed wrong.
You reroute belt.
Now belt is too tight.
It only makes sense to gt the correct belt and route it the correct path. Unless the first new belt you got was indeed the incorrect belt(which does happen a lot)
If the belt is correct, and routed correctly, then I would have your charging system tested for free at a shop somewhere.
Chris-bob,
Really? a whole inch? that really seems a bit excessive to me and my previous experience with other manufacturers - my Saturn has only a 1/4 inch of play - My Explorer has only a 1/4 of play -
The problem with the belt I first purchased was the belt was too long, and the tensioner bottomed out - meaning, no tension was put onto the belt at all. I am a bit aprehensive to get the same belt because I see very little "lenght" change between the "wrong" belt path and the "correct" pathway. As such it would seem getting that longer belt would only do the same thing, bottom the tensioner out.
In any case, I will take my Disco over and get the charging system checked to make sure the alternator is working as expected.
Thanks so much for your input, it is enlightening and helpful...
In Peace and Agape,
Trav...
In Peace and Agape,
Trav...
rockcity
Jan 5, 2011 11:13 AM
DRROVER
Jun 16, 2006 02:57 PM
