Brake Caliper Nut Size
Easy, but a pain in the *** to have to stop working, clean up and drive to sears. I've gotten them off without them breaking, but newer Craftsman sockets aren't as good quality as the old stuff. For small high torque applications, like caliper bolts and head bolts, I use one of the high quality brands. This is from someone who's been using Craftsman for over 50 years, starting with my dad's when I was a kid.
On a serious note, I just busted a drive flange bolt because my Craftsmen "digi" torque wrench gave up the ghost. I knew it was broken but was trying to use it anyway. Of course it didn't indicate the 68Nm or whatever it was, and I twisted a bolt off. Fortunately the broken shaft came right out, still wet with Loctite.
I used a box-end wrench to multiply the the torque measured by my inch-pound wrench on a bolt/nut in the other end, to finish the job and ordered a new wrench. I don't use a torque wrench enough to justify a really fancy load-cell type, but I like this one because it seems to be high-quality, was calibrated meticulously (certificate included), and it covers the gamut of Land Rover torque values. Oftentimes wrenches go up to 100 ft.lbs (and you'll need another one for the few higher torque nuts and bolts like the radius arms), or they go up to 200 or 250 ft. lbs in which case they're less accurate with the most common lower torque values. This one has a range up to 150 ft. lbs, which means it's pretty accurate down to 30 ft. lbs or 40Nm.
