Brake line question
Old May 13, 2012 | 08:19 PM
Jake1996D1's Avatar
Default Brake line question
Re-plumbing my rear brakes in the truggy I ran into a small issue...... What size is the one on the right??? The line is the same size but the nut is bigger than the M10x1.0 that they used for the rest of the system... What a pain in the ***!! I'm thinkin I am going to have to special order an adapter piece now
Old May 14, 2012 | 01:04 PM
antichrist's Avatar
If you're removing the ABS just cut it off and install an M10x1.
Old May 14, 2012 | 01:06 PM
Jake1996D1's Avatar
I'm not removing ABS at this time although I probably should have. - you responded to this post over on Dweb too - I'm gonna go pick up the adapter piece now..
Old May 14, 2012 | 04:05 PM
Jake1996D1's Avatar
For future reference it is M12x1.0 and I just bought an adapter at Autozone instead of reflaring the tube..
Old May 14, 2012 | 10:01 PM
antichrist's Avatar
I trust you double checked to make sure it was for ISO bubble flare and not metric inverted flare.
Old May 14, 2012 | 10:40 PM
Jake1996D1's Avatar
Yea I got the right part hahaha - here's the part number for those looking for it in the future
Dorman/AutoGrade M12 - 1.0 x 3/16 in. male to M10 - 1.0 female bubble flare brake line specialty adapter (788-522) | Brake System Adapter | AutoZone.com_
Old May 15, 2012 | 06:02 AM
antichrist's Avatar
I figured you had, but I was only seeing inverted flare on the Autozone site. Then again I wasn't looking for a long time. Plus I was looking for a coupler rather than an adapter. I wasn't sure exactly what you were doing.
Good to know they have them.
Old May 15, 2012 | 08:03 AM
Jake1996D1's Avatar
Me too thought for sure I was going to have to order it online
FLDiscoII
Sep 1, 2012 09:23 PM
JerrodSteph
Jun 12, 2011 06:04 PM
GeorgeD
Mar 13, 2009 07:46 PM
Jupiter Rover
Feb 27, 2009 01:04 PM
ajh
Oct 28, 2007 02:24 PM
