camel cut
Old 03-15-2011 | 05:02 PM
tweakrover's Avatar
Default camel cut
Thought you guys would apperciate a pic, this is where the tire hits under flex. these are 245/75-16s with a 2" terra firma med duty lift.
It hits on the angle at the bottom where it comes back in
Old 03-15-2011 | 09:38 PM
thehun's Avatar
camel cut is a must if you wheel...in my honest opinion..im actually going to roll my fenders inside as well....
Old 03-15-2011 | 10:40 PM
tweakrover's Avatar
yea i did one tonight but haven't had time to make sure it clears. I just basicaly folded the bottom flap up and the flat part of the arch back, so I'm hopeing the tire will tuck up in there now. I will see tomorrow and take some pics.
Old 03-17-2011 | 06:41 PM
tweakrover's Avatar
didn't work
I rolled the bottom up and the lip back but I don't think it will be enough
this is full flex, i could lift the bumper and pull the rear drivers wheel off the ground
if I'm wheeling a good bump would take it passed this point and its not enough clearence
so whats the best wat of actually trimming it, cut it leave it long and fold it over?
Old 03-17-2011 | 06:53 PM
Cosmic88's Avatar
Default tried and true
great method...
Trimming the Wheel Arches on a Range Rover
Old 03-17-2011 | 06:55 PM
echomike's Avatar
thanks for posting.
Old 03-17-2011 | 09:30 PM
tweakrover's Avatar
ok nice but not looking to do the whole arch. just the back last 8 inches.
Old 03-17-2011 | 10:00 PM
Long Haul's Avatar
I would cut and fold myself it stiffens the fender up over just cutting, but it is tough to do since you are only doing just the bottom few inches.
Old 03-18-2011 | 04:08 PM
tweakrover's Avatar
yea what I'm really trying to figure out is how to transition from the flat inside lip to new part I fold over.
Old 03-18-2011 | 07:32 PM
Cosmic88's Avatar
Default fold then cut....
here's mine... using the black rubber trim (parking lot protector) as a reference point, about 3/4" below the top edge of the rubber make a cut (metal shears) about 1/4" shy of where you plan to fold the curve of the inner arch. I'd sugest saving all the trimming until the very end after you have folded the metal into a new triangular shape at the angle you need to fit your planned tires. this way you can still have a 90* inward fold from the exterior plane for strength. then trim the inner edge to folow the tapered line from top to bottom like the original.
You will end up with some cracked paint at the fold point but that's a small sacrifice.
soft faced, wide pliers or a couple bits of wood in the plier jaws to protect the fender at the fold line is good.
Quick Reply: camel cut
