Can I fit 235/85/16 with no lift?
Old Aug 21, 2010 | 01:36 PM
Spencerfitch's Avatar
Default Can I fit 235/85/16 with no lift?
Im asking because I can get 4brand new wrangler mt/r mounted and balance for 350$
This deal will only last till the end of the month and i might not be able to afford a lift and tires at the same time.
Old Aug 21, 2010 | 02:19 PM
LRadventure's Avatar
even if they dont spence, That deal is good enough that i would hop on it, hold the tires till i COULD afford a lift, If you have an extra set of rims layin round that is..
Old Aug 21, 2010 | 05:54 PM
sure is, Im not a fan of goodyear but what ever. Ill probably get 5 there so cheap.
And yes I can drive without a lift, will need to adjust steering stops and not take it offroad untill I get a lift.
Old Aug 22, 2010 | 04:30 PM
tweakrover's Avatar
I think even with the lift 235/85's will rub if you dont do some trimming of the inner fenders, just what I've heard. I would go for it.
Old Aug 23, 2010 | 10:21 AM
AK Rover's Avatar
With a lift and the steering stops adjusted properly you can run 235/85s with no problems. No need to trim anything. Without a lift you'll rub everything with that size tire. Any slight suspension movement and you'll rub the fenders.
Andrew0
May 31, 2015 08:35 AM
COBRA
Mar 25, 2013 09:41 PM
herblatham
Mar 1, 2009 12:02 PM
s4lex
Aug 11, 2008 04:58 PM
s4lex
May 2, 2007 10:10 PM
