Can you help identify this connection?
2 Attachment(s)
Hello Good People,
Can some please help identify this connection that is in the same area as the cruise control electric connection(under the the bottle jack) T.I.A. |
Transmission cooler line temperature sensor. Between steering box and radiator
Thanks RedRovin!
Its not connected to anything..YIKES! |
You're Welcome. I believe its more of a safety switch than anything. Truck can run fine without it, but you wouldn't know if the trans cooler malfunctioned and started overheating the oil.
Okay I see.
So its been unplugged since I had this rig. If properly connected would this display some light on the gauge cluster? |
Only if your transmission has been over heating.
Thanks again for the quick response RedRovin!
My pleasure! Best of luck
Does anyone know the correct P/N for the transmission temperature switch??
My light has come on and stayed, want to change out the switch and see if that fixes it, thanks!! |
https://cimg6.ibsrv.net/gimg/landrov...915dff6ef3.jpg
Originally Posted by FloridaRover
(Post 641966)
My light has come on and stayed, want to change out the switch and see if that fixes it, thanks!! New Number: 8510043............ Old Number: AMR4948 |
