Connecting to OBDII port problems
Old 04-03-2018, 09:03 PM
deer4011's Avatar
Default Connecting to OBDII port problems
Over the past few months Ive been trying to reset my adaptive values so far I think Im on the right track but Ive hit a snag. When I started I used a T4 to check codes and see what some of the operating values were looking like. I had no codes and all operating values were normal. Great, no problems there the rover would talk to the T4 all day long. Next step was to plug in a Autologic computer which would be the first attempt at a reset. However I could never get the Autologic to talk to the ECU. It would just say connection failed or no connection. The guys at the shop didn't think it would connect because they hadn't used it on a D1 in years so I figured that was the case. Fast forward about a month. Im now trying to use my laptop to talk to the ECU and send a program that someone wrote on another forum to reset the values. However, I can't get my computer to connect now. So Im thinking its a problem with my car now. I unplugged the ECU and opened it up and it looks brand new inside. Ive tried to chase the wires to see if any are loose but so far they look good. So im wondering if anyone has ran into this before or knows of something that im looking past.
Old 04-04-2018, 07:16 AM
WaltNYC's Avatar
Check fuses 12,13,& 14 on the main board and fuse 3 on 'satellite 1' (the row at the top)
Attached Thumbnails Connecting to OBDII port problems-fuses-2.png   Connecting to OBDII port problems-fuses.png
Old 04-04-2018, 03:47 PM
deer4011's Avatar
Fuses all check out to be good. Im going to put dielectric grease on the ECU plugs and the OBD plug to see if that makes a difference.
Old 04-04-2018, 06:26 PM
ihscouts's Avatar
Honestly the Data Link Connector fuse is F3 10A in Satellite Fuse Box 2. Check Pin 16 on the port for 12VDC. The only time I ever had a problem with a device latching with the ECU was when that fuse was kaput, drove me nuts.......
Old 04-04-2018, 10:47 PM
deer4011's Avatar
Weird mines a 20A but it looks good. Ill get a mulitmeter on it tomorrow and check the voltage and report back.
PS: I put dielectric grease on the ECU plugs and OBD plug and it made no difference.
Old 04-05-2018, 09:50 AM
WaltNYC's Avatar
Yep, ihscouts is correct. I missed that one. Nice pick up.
Old 04-05-2018, 11:18 AM
ihscouts's Avatar
Been there, done that including dielecric on ECU connectors to no avail. Just say'n.
Old 04-05-2018, 03:57 PM
deer4011's Avatar
So new ECU and alarm box?
Old 04-05-2018, 04:29 PM
ihscouts's Avatar
........Scanner not connecting to the ECU.
Old 04-05-2018, 05:06 PM
deer4011's Avatar
Still haven't checked the voltage at the port. Ill get to that later today and post the voltages I get at each pin. No clue if that is gonna help but its worth a shot.
Quick Reply: Connecting to OBDII port problems
