Coolant Loss Question - Only Losing a Certain Amount
Double check the reservoir. I had coolant spray in areas and couldn’t for the life of me find where it was coming from. Turns out there was a tiny crack along the reservoir that spewed out coolant when it got hot. It never dripped or puddled anywhere. Just a thought. I reolaced my black reservoir and good as new.
It arived today and I gotta say Im happy - its thick plastic
I have a Ford Ranger (a proper Gentleman does not own/drive/depend-on a Land Rover alone) that leaks coolant down to a certain point and no lower. I pictured an imaginary plane at that level and checked everywhere there was a coolant at that height. It was the thermostat housing (common problem on that model).
Thanks everyone for your input. I ended up ordering a new expansion tank from Rock Auto and installing it. It is pictured below, old on the left, new on the right. After about 500 miles and several days of driving, my coolant hasn't dropped an inch! Upon further investigation, I couldn't find any leaks in the old tank or splits in the seam. But when I was going to remove the old tank, the engine was still warm, and I noticed that the expansion tank cap was a little wet. It almost looked like steam "residue". So I am assuming that there was a fault in the old cap that led to the pressure or seal in the tank to not function properly and coolant either leaked through the cap or was released as steam, I don't know.
The new tank from Rock Auto is nearly the same shape, but all of the connections are the same and there is zero issue when installing it. I would say that if you have a similar problem, this would be a good thing to try given how cheap the tank is.
Also that tank is so much easier to see what level the coolant is at, might do the same with the washer fluid bottle, the white really ties the bay together.
It could be something hose related.
Ive had my share of coolant issues. I replaced water pump, a couple hoses, viscous fan, coolant tank cap, the thermostat, the original radiator and still I was getting a leak. I replaced the cylinder heads and changed the head gaskets. In the end it turned out to be the coolant reservoir that needed to be replaced. I drove it for over a month with no leaks (parked it under a large piece of cardboard). Oddly I added a bottle of water wetter up to the full line and damn, a small coolant puddle soon appeared on the cardboard. Add to that the newer radiator has a Winter leak due to the construction of its aluminum and plastic body!
Maybe you haven't seen much action on the gauge due to the colder weather and your thermostat not opening depending on how far/long your driving.
Some one with additional knowledge will soon chime in.
I'm totally buying that $8 tank if they'll ship it north. Good find, thank you for sharing!!!!
user 739349 (02-06-2019)
