Diff Troubles
Old Feb 25, 2013 | 07:32 PM
toddles1987's Avatar
Default Diff Troubles
Hi Guys,
I recently bought a 1998 Discovery 1 td5 automatic.
Occasionally as I slow down, the diff selector will slip into neutral, meaning I have to stop, put trans into neutral and go back to high range.
It has done this a few times in the last two months. I also cannot select high range, neutral and low range on the diff selector by moving the diff selector forward and backwards. I have to move it to the left first.
Am I up for a new transfer case or is there something else I can do?
Thanks.
Old Feb 25, 2013 | 08:53 PM
There is a spring inside the t-case that holds the gear selector in place, sounds like yours is bad or maybe broken some how.
Drain it, remove the inspection cover and have a look see.
cornbreadj
Dec 27, 2014 07:50 PM
dusty1
Dec 7, 2014 01:57 PM
Disco2Guy
Jun 20, 2008 10:13 PM
Sean 1313
Jan 13, 2006 06:25 AM
Dave_Liverpool
Jun 22, 2005 11:29 AM
