Disco 1 Lift Kit
Old Apr 25, 2020 | 10:11 PM
chandlerhayes01's Avatar
Default Disco 1 Lift Kit
Looking into getting a 2-3" lift kit for my 98 discovery. I have a few questions
1. any modifications to driveshafts needed
2. any mods to steering needed
3. most kits just look like they come with springs and shocks, i am just curious if anything else needs to be upgraded.
Thanks All
Old Apr 26, 2020 | 06:13 AM
Toran's Avatar
You should be good to go with the shocks and springs. I went with the TerraFirma 2inch kit sold by British Atlantic when I got my 96 D1. The PO had 1inch spring spacers in place that I left on, 4yrs later and everything has been fine. I also replaced the steering damper just to be on the safe side since I didn't know the condition of the installed on.
You have options betweens full length springs and different spacer sizes, heavy/medium/light weight springs etc.
Have a grease fitted driveshaft is a must too.
Old Apr 26, 2020 | 09:13 AM
im definitely going with springs and shocks. I just wanted to make sure non of the other drive line needed to be upgraded. im pretty sure that i have greasable drive shafts. i was more or less curious about the steering geometry and driveshaft angle.
Thanks
Old Apr 26, 2020 | 10:46 AM
Toran's Avatar
You should be good to go!
Anything about 4 to inches and you'll need an additional parts configuration.
Pay attention to the springs as they will be labeled front and rear. And the driver side spring will be a bit different than the passenger side.
Old Apr 26, 2020 | 11:17 AM
im looking at doing the 3 inch springs, and the fender flares
Old Apr 26, 2020 | 03:46 PM
Toran's Avatar
Sounds cool.
Take some images before and after.
Old May 4, 2020 | 05:56 PM
i have got a set of 2" springs delivered today.
What is a decent entry level shock to get for the land rover? It is not daily driven by no means so i am looking for something cheap.
Old May 4, 2020 | 06:15 PM
Best4x4's Avatar
Pro Comp ES9000 for a D1 are about as cheap as I'd go. I personally think they aren't that bad for the $$$. Then TF shocks would be second.
Old May 5, 2020 | 07:01 PM
OverRover's Avatar
Pro-Comp ES9000 for sure.
RN sells a set of 4 with boots for $239.00 (PCS9030) > https://www.roversnorth.com/parts/pc...overy_i&type=3
The way better deal is at 4wheelparts.com for $175.14 (with shipping) for the EXACT SAME set up.
> https://www.4wheelparts.com/
You can also order these from SUMMIT Racing and they will match the 4WP price. Sometimes a better option because Summit ships crazy fast.
For 2" lift:
FRONT: # 922560
REAR: # 922573
BOOTS: # 12127 (for BLACK they come in many colors)
EXAMPLE from 4WheelParts.com CART >>>>
jycsalas
Jun 21, 2022 01:44 PM
miron
May 30, 2019 06:38 PM
LRlax11
Sep 12, 2014 11:35 AM
theworks001
Nov 17, 2008 10:31 AM
sailorcolin
Feb 11, 2008 02:28 PM
