disco 1 vibration need help
I have a 97 disco 4.0... have a vibration on start up hot or cold sounds like a miss? there's always a shake at all rpms not real bad but its there did a tune up plugs wires have plenty of power a little lost here was wondering if any one else has had this type of problem Is there any thing an look for? obd doesn't find any codes cats have been deleted besides that all stock
put a block of wood under the oil pan and use a floor jack to slowly attempt to raise the motor......if the mounts are bad you'll know right away as they will separate with only a little effort
The miss was there before the tune up plugs and wires didn't help it all .The old plugs looked good or should I say looked the same its never over heated or anything like that could it be a fuel pressure problem just in the last week it's starting harder it act like theres no fuel leave the key on for 10 sec then try it starts right up wondering if low pressure could cause this and what to look for ill check the mounts tomorrow after work and see what those look like can't keep throwing money at it wife will kill me .....she even said I should just sell it.... but shes crazy !!!
