disco 1 vibration need help
Check the mounts as mentioned. I have seen cars with a weak spark do this only at idle. The way to find it is to buy a spark tester (a few bucks at HF) and check for a BLUE spark to every plug. A yellow or orange spark can be considered weak and cause a stumbling at idle that you wont notice on acceleration or cruising. If you do notice a weak spark, chances are you need a plug wire or a coil.
You just fool the DS o2, as long as the DS has a lower ppm reading it thinks there is a working cat, can be done using a couple spark plug anti foulers to get the sensor shielded from the gases
I had this Jeep with the 5.9L, may it rest in peace, that was doing the same thing.... light skip at idle, slight piffing sound in the exhaust (flowmaster, so sweet on that big motor) when #8 cylinder missed, but give it a little gas and get on it a little and it smoothed right out and ran great. Turned out to be a compression issue
Have good blue spark on all 8 no fouled plugs whats good psi for compression haven't got to the motor mounts yet and yes the cats are gone the obd shows no code also tried a snap on scanner on it it shows no codes it runs much better with out the cats and cooler is there a way to test the injectors ? And thx for all the suggestions ! Anyone know if theres a good place in indiana for a rover?
There's bits in the RAVE about leaky injectors too. Something about drips per minute or something. I didn't read it too closely. Worth looking into.
striversrowatl
05-01-2010 11:20 AM
brianex
11-02-2008 06:16 PM
