Unfortunately, removal of the sunliner is necessary to gain access to the area to correct the problem. As was stated, there are two main items that leak.
1. The drain tubes can get clogged and not drain properly which will overflow and leak. If the tubes got punctured then somebody used the wrong screws as that should not occur. So pull the headliner and see what iti is. 2. The corners of the metal track are sealed at the factory with a blacl silicone caulking. Mine developed a drip right above the drivers seat. I see no sense in trying to seal a sunroof unless you are just too lazy or busy or whatever you want to call it to take out the headliner and correct the real issue. I enjoy my sunroofs way to much to even consider sealing them. If you feel otherwise, that is up to you. It is yours so do what you will with it. The headliner has nothing to do with the AC unless you are referring to the rear air. And I do not know if that comes into play either. The reason the headliner sags is due to the foam layer between the cloth and the fiberglass form comes apart with age. |
Originally Posted by Danny Lee 97 Disco
(Post 287299)
I see no sense in trying to seal a sunroof unless you are just to lazy or busy or whatever you want to call it to take out the headliner and correct the real issue.
I enjoy my sunroofs way to much to even consider sealing them. If you feel otherwise, that is up to you. mine are still functional. for now. however my truck isnt a DD and opening them on the trail they sound like they are going to snap at the rails. last time i had the rear open it got stuck open and it started raining. had to have someone jump up and give it a push to get it started. have not opened them since. |
I found this on the net about installing a new headliner, nice replaccement with pics
The best amateur photography lives on Webshots |
I took mine off last week. Caulked up the drain plugs, adding some new hose where it was all dried out and smashed in one area, cleaned out both drain hoses and it rained today and guess what...still leaks! lol
What I have figured out that might be the cause is that my rover is lifted about 2 inches and it seems that the rear of the car might be a tad higher than the front which might not allow the water to drain out the rear and fill up the rear sunroof causing it to overflow into the cabin. I'm going to test this out soon. |
Originally Posted by hilltoppersx
(Post 285362)
the headliner will sag no matter the sunroof leaking or not. thats why i made the painting the headboard write up in the tech section. no more fabric = no more sagging
Could easily be tubes, sunroof seals themselves, window seals. Alpines are notorious. Headliner could redirect leak from almost anywhere on the roof to anywhere else. Danny posted the water ingress guide for most common points. IMO, you have to pull the headliner and check/shore up every possible point of entry. If you don't do a complete job, rain will get in, destroy the new headliner and make you do it all again. Kinda sucks and I'm starting it now after letting it cause far too much damage.
I parked it up on the curb so the front end was higher than the rear.....
and no leaks... Now I have to figure out how I can make it drain sitting normally. |
Does any of this apply to a DII? Because my wife's has a leak and I am just assuming that it is coming from one of the sunroofs. The thing is, it only leaks when parked in the driveway head first slightly up hill.:confused:
Originally Posted by Mr. Clean
(Post 292726)
(Post 292726)
Yes, D1 and D2 sunroofs are exactly the same, totally interchangable( i believe). |
