Originally Posted by psykokid
(Post 292731)
makes sense, the drain channels are at the front of the sunroof assembly, with the truck angled uphill the water is going to overflow the drip rail and leak if the sunroof seal isnt good..
Originally Posted by kenk
(Post 292807)
Yes, D1 and D2 sunroofs are exactly the same, totally interchangable( i believe).
Can you clean the drains without taking the head liner out/ down?
Afraid not. But if you have issues with the sunroofs, it is best to go ahead and remove the headliner (not the sunroof) and deal with the sunroofs. The longer they leak, the more damage will be done to the headliner. The drains are large clear plastic tubes routed behind the headliner to the side rails. The sunroof frames also can leak at the corners and need to be sealed with caulking. |
Originally Posted by Danny Lee 97 Disco
(Post 293261)
Afraid not. But if you have issues with thye sunroofs, it is best to go ahead and remove the sunroof and deal with the sunroofs. The longer they leak, the more damage will be done to the headliner. The drains are large clear plastic tubes routed behind the headliner to the side rails. The sunroof frames also can leak at the corners and need to be sealed with caulking. |
