Ecu?
Old Feb 19, 2015 | 01:01 PM
Hanomag's Avatar
Default Ecu?
Hello
I really need your help and advice about an issue with my Rover. I was having an issue where the electric fans would not ever engage and was trying to fix one night after work (in the dark, and in a rush) I disconnected the coolant temp sensor (the one by the gauge sender) because I thought it was the switch to the electric fans. I then hooked test leads to the connector and applied power from the battery! The car instantly stalled and now will not run unless I keep the revs up with the gas. I think I may have ruined the ECU? I have searched the net a bit and I think that the sensor was directly connected to the ECU to provide engine temperature to the fuel injectors? Can I fix my Rover or is it a goner?
Old Feb 19, 2015 | 01:39 PM
EricTyrrell's Avatar
Originally Posted by Hanomag
Hello
You'll probably need a new (used) ECU. To be sure you'll have to check the ETM to see what electrics are inline with that circuit and might be fried.
Old Feb 22, 2015 | 06:30 PM
Hanomag's Avatar
I have an update on the Disco. A member on the forum contacted me and gave me a great deal on a new (used) ECU to see if that would fix it. Well I should be getting the ECU soon and I will be installing it as soon as it comes….but in the mean time I figured why don't I pull the ECU and see if I can visually stop the issue. Well I did just that, I pulled the ECU and found a tracer wire that was a little burned and smelled like electric smoke. I soldered in a new wire and now the Disco runs great so I am sure that the ECU is the only issue.
I am very happy and excited to install the new ECU when it comes now that I am sure that will fix the issue and keep me reliably on the road.
Old Feb 22, 2015 | 09:42 PM
TOM R's Avatar
What year is your truck?
Old Mar 2, 2015 | 11:25 PM
Hanomag's Avatar
It is a 1998
Old Mar 3, 2015 | 07:07 AM
TOM R's Avatar
If you install the repacement and it is stuck on high idle you will need it reset
Old Mar 7, 2015 | 06:49 AM
RedRovin''s Avatar
Can resetting an ECU be done by mailing it to someone or does it have to be installed in the vehicle? Also what system is required to reset it?
I recall reading only one type of system had the full capability to reset an our ECUs.
Old Mar 7, 2015 | 07:02 AM
fishEH's Avatar
You need TestBook to reset it.
I think PT Schram may do it by mail.
Paul Grant
Aug 10, 2014 12:29 PM
etrnly
Feb 2, 2006 02:07 PM
Rob
Oct 6, 2005 11:48 PM
JRdisco1
Aug 25, 2005 03:07 PM
