Electrical "click" when getting out of 5th gear.
Yeah I didn't think there was, i was trying to describe the sound. It sounds like when you throw one of those poppers you throw on the ground around the 4th of july. It is only when I put it in 5th gear and take it out. It happens even when the truck is not on. I will try and get a video and upload it somewhere.
Could be the detents making noise when you shift in and out of 5th gear. There are two metal forks that act like springs to bring the shifter to it's correct position in nuetral that can make some noise even when the car is not running. Mine makes a similar noise when I shift into 4th. Hope this helps.
![Stick Out Tongue](https://landroverforums.com/forum/images/smilies/peaexB2.png)
ab4x4
02-18-2015 02:22 PM
