Finished the rust renovation and new floor
Old May 15, 2012 | 09:25 AM
  #31
slanginsanjuan's Avatar
nice. that'll all work.
are you using a sealing paint?
my carpets and padding were unsaveable and my truck was entering a new form as a third world urban crawler. my new floor suit me well. ill keep the rugs and forgo the lift in the d2 tho.
Old May 15, 2012 | 09:28 AM
  #32
pinkytoe69's Avatar
Yeah, Ill get some regular rustoleum on there when Im all done.
Old Jul 1, 2012 | 08:15 PM
  #33
b63215b's Avatar
Default Rust Repair
I just wanted to say I am brand new to the forum and your posts have been most helpful. I have the same issues not as bad but still pretty rough. I see now I do not need to remove the entire floor. I have a couple questions.
1) Did you have rust bad in the rear wheel arch?
2) What was the insulation you used? (my old insulation smelled like cat pee so I am not leaving that in there.
3) Can you explain the purpose of the cardboard again under the fiberglass?
Thanks so much, you have been most helpful.
Josh
Old Jul 2, 2012 | 09:10 AM
  #34
Josh
Thank you. No one has ever said that to me before.
Bad? No. The pics show the holes I believe. A few silver dollar size holes. Check your firewall too.
I removed all carpeting and insulation as mine also smelled like cat pee. I put a layer of metal (diamond plate and sheet) over most of the floor. In between was a layer of foil and fiberglass insulation..pretty standard stuff and widely available. Got mine on ebay. You can do better but it's inexpensive and works good for heat and sound.
The fiberglass on application is wet and gooey. If you don't support it with something underneath it will sag and drip. The cardboard let's it set. You may have to apply more of the epoxy part to the bottom to seal it in. You don't want stuff getting up in between the original floor and the new floor.
Anything else? Let me know.
Old Jul 2, 2012 | 05:34 PM
  #35
Danny Lee 97 Disco's Avatar
Slang,
Did you find out what is getting that floor pan hot?
You have been a very helpful bro to me as well man.
I did see those entire replacememnt floor pans on EBAY UK, if you had advanced rust that would be a great option but a lot of work.
Slang was fortunate and had the panels and made excellent use of what he had. He has motivated me to take a fresh look at redoing more stuff on mine soon.
The last couple of weeks I have been outback redoing my redneck love shack trying to get it ready for a Fourth of July Party and Sendoff for the DIL and grandkids returning to NC. The heat wave has been brutal but I put a reflective aluminum foil trucker's cooler tarp over the southern exposure and it made a huge difference.
Old Jul 3, 2012 | 08:04 AM
  #36
you're too kind danny....and i'm no farther along on any of my projects so i'm trying not to post.
Old Jan 13, 2016 | 11:08 AM
  #37
Toran's Avatar
Thanks for sharing!
Your postings with images will come in hand when I start this same project later this year!
Thanks
Discolife
Jan 2, 2013 09:22 PM
slanginsanjuan
Nov 18, 2011 06:33 AM
GreedyRover
Sep 19, 2011 03:56 PM
Dottieshusband
Oct 15, 2010 01:00 AM
Princess
Sep 15, 2009 08:02 PM
