Fixing the hot handbrake, before it spontaneously combusts.
Old 02-16-2013 | 09:20 AM
SSL9000J's Avatar
Default Fixing the hot handbrake, before it spontaneously combusts.
Yes, I have the dreaded "grounding through the parking brake cable" problem, that I don't want to turn into the "Disco Inferno" problem. (Sorry, couldn't help it.) But it only happens when the lights are on, everything's fine in the daytime. Careful study of the Rave revealed three ground locations nearby: E301/E302, under the driver seat, and E303 under the console. (The white connector in the upper middle of the photo, under what looks like a mounting screw.) This, obviously, seems the most likely culprit.
Are there any others I missed that I should be looking for? I'm going to pull up the console this afternoon to replace the parking brake lever.
Thanks all!
ledlover2
08-23-2008 10:34 PM
whurst79
06-18-2008 06:51 PM
Camdisco24
05-01-2007 05:34 PM
ROV413
12-15-2006 06:52 PM
Quick Reply: Fixing the hot handbrake, before it spontaneously combusts.
