(Post 640409)
If the diameter is the same how does it have a longer foot print?
Also the Camel Trophy teams drove those trucks with zero cares on damage. Tires are quite literally the one item the least associated with damage on the camel trophy. How does them using skinny tires equate to more damage? Saying zero cares is hyperbolic. |
Thanks for the response Gents! Sounds like my buddy in South FL has a set of OME 751 and 763 HD springs and Terrafirma shocks that should work
I don't mind doing a camel cut, will take a hard look at the 265/75 sizes, I am running 265/70's on the D2 with no lift or rubbing |
This is the look I'm going for at first, I kinda like the factory brush guard, maybe with a recessed winch tray tucked between the frame rails
http://i64.tinypic.com/1zdulx1.jpg |
Originally Posted by DavC
(Post 640469)
when you air down tires the skinnier it is the longer the footprint versus a wider tire aired down looks more like a square footprint
Tires are quite literally the one item the least associated with damage on the camel trophy. How does them using skinny tires equate to more damage? Saying zero cares is hyperbolic. Still don't see how a wider tire would have a shorter foot print. Do you mean it appears shorter? Not trying to be argumentative just not tracking. |
Those factory brush guards are not very robust. I had one originally on mine.
Is it me.or does that silver Disco have MTs on the front and ATs on the back?
(Post 640541)
I'm saying they didn't care what happened to the truck period. So if you aren't worried about damage then small tires/big tires don't matter, more speed solves a lot.
Still don't see how a wider tire would have a shorter foot print. Do you mean it appears shorter? Not trying to be argumentative just not tracking. As for the skinny v wide there was an Andrew White video a few years back, best visual explanation that I know of, but cannot find it, thus can't push the point. Essentially as the tire airs down more and more of the carcass makes ground contact, the wider tire carcass pattern an expanding square-ish shape while skinnier gets a bit wider yes, but the ground contact pattern elongates. |
We will just have to agree to disagree on the CT portion.
Tires no idea |
Originally Posted by WaltNYC
(Post 640598)
I figure I can find one for cheap and throw it on for the factory look, I don't plan on hitting much with it |
(Post 640613)
Would like to get another set of Swampers under my silver one |
