Front Cover....where did this washer come from????
1 Attachment(s)
Okay, I am in the process of replacing the front cover gasket. When I removed the assembly, I put it aside with the bolts in the holes. In the process of doing that, I accidentally dropped a few bolts and the thick washer (the one in the picture).
I looked through the RAVE and didn;t find any reference to it. Does this washer mount with the camshaft sensor bracket? It looks like it does.....frick.....:confused: Thanks in advance.... |
would PM Boris_gti, he just replaced his several times... has a post on it with what he thought was a crack...
Maybe it's extra. :)
I know that the oil pressure switch has an o-ring if you install it on a serpentine belt engine (like our discos or the 95 rrc) but it has a washer if you install it on a v-belt engine. Maybe someone dropped it when replacing the oil pressure sender. |
(Post 279468)
Originally Posted by jafir
(Post 279477)
2 Attachment(s)
The only 2 places that I am fully aware that washers like this are presend around and in the timing cover:
1. Under 3 nuts that hold the oil pan to the engine cover. Bolted under the timing cover for M8 bolts. 2. M6 or M5 hex bolt that holds the oil pump cover on the inside of the "front engine cover". You got few philips bolts and one hex head bolt. Original cover and oil pump do not have this washer. It only comes with the replacement cover. I removed my washer since I didn't trust it that it will not create problems. I used the bolt from the original cover. That's it. Check the size of the washer and see if it most likely came from the 3 M8 bolts that hold the oil pan to the cover or maybe that M6/M5 bolt that holds the oil pump plate on the inside. There is no washer under the cam sprocket bolt! It could be that someone dropped the washer in somewhere from the top of the engine long time ago and the washer ended up in the front engine cover. See images attached. Hope this helps. P.S. DO NOT PAY ATTENTION TO THE BEER BOTTLES IN THE FIRST PICTURE. IT'S NOT MINE LOL! |
Boris -
We knew those were not your beers - they weren't Blue! |
Originally Posted by groundandpound
(Post 279545)
Boris -
We knew those were not your beers - they weren't Blue! Anyways....I was thinking about this last night again. It also could be that the washer was dropped from one of the M6 bolts that hold the cover on as well. |
Boris...thanks for the help.
I could not find where it goes. All the bolts depths are in good and not need for it. It must have been sitting in there all this time....???? I while cleaning all the bolts to the sump, I also found ONE bolt that is longer and I am missing all but two bolts for the bottom of the transmission bell housing cover... Humm........from looking over the internals, the top looks like it has been service...I guess that is a postitive from all this.... |
I don't remember any washers when I did my front cover and oil pump replacement.
I found where it goes....for the sump cover. The longer bolt and washer mount the bracket for the tranny cooler. Problem solved!
Thanks again all for the help! |
