Fuel line integrity test
Old Jan 2, 2013 | 04:16 PM
PaulsDisco's Avatar
5th Gear
Default Fuel line integrity test
I am just finishing up a HG job on my 98 disco.
Things have gone quite well thanks to the many great posts here.
What I was wondering is if I can test the fuel line integrity under pressure before I install the ram air housing and plenum?
Any problem turning the ignition on to get the fuel pump running to pressurize at this point?
I'd rather find leaks, if any, now rather than tear things apart again.
Any recommended sealers between the manifold/ram housing - ram housing/plenum ?
A tech where I had the heads done recommended an "Anaerobic" gasket maker/sealant, or stick to the "Hylomar" as the RAVE recommends?
Old Jan 2, 2013 | 09:49 PM
XCELLER8's Avatar
the anaerobic sealer will give you a much longer working time before it sets up (it never really drys hard anyway) but either are ok.
IMHO as long as you've got everything mostly hooked up, testing for any leaks would be fine
twilightcall
Jul 19, 2011 01:17 PM
JerrodSteph
Jun 12, 2011 06:04 PM
JumPeR04
Apr 7, 2011 09:52 PM
Rfactor
Jan 3, 2008 02:46 PM
