fuel pump noise question
Im hoping i can find whats causing my hot start issues along with another issue that happens occasionally. The other occasional issue is when I first go to reverse the vehicle and give it gas it will cut out for a split second and gives a small slight jerk.
Anyways. listening closely today I turned on my key heard the fuel pump whirl and then a "skip" or stop that got closer and closer until the relay clicked and the pump went off. They way it sounds it almost sounds like its supposed to do this. BUT.. The only way for the fuel pump to "skip" or stop would be with the relay deactivating and you can hear when the relay REALLY turns off. So is this normal? Any way to check fuel pump?
have you checked the fuel pressure lately ? and..can you check it a few random times...by leaving the fuel pressure gauge hooked up ( duct tape it to the windshield if you have to) this wont tell you everything but if there's a drop in pressure or a leakdown you might find it this way. I havent read your other post on this but a clogged fuel filter can slow down the pump, and a out of spec fuel temp sender can give you hot start issues...
i check the pressure often always at 33psi but NEVER when it has the stumble problem. Fuel filter is pretty new. I just heard this noise and wanted to see what others though. Im thinking I might have a leaky injector when hot..
Travelor
Sep 24, 2015 06:11 PM
JumPeR04
Apr 7, 2011 09:52 PM
atikovi
Apr 7, 2007 03:27 PM
