GEMS Engine Management Manual
5 Attachment(s)
Please find attached the GEMS engine management manual, includes codes and how they are calculated, etc. For 96-99 D1 and other vehicles. aka ecu ecm engine computer cpu
Also background material on earlier Lucas versions If you are looking for D2 versions, see https://landroverforums.com/forum/di...manuals-48009/ |
You sir..........are a gentleman and a scholar..........
Much appreciated..... |
Added similar detail for D2 in a separate post - Bosch M5.2.1 "Motronic" https://landroverforums.com/forum/di...manuals-48009/
Sava,
Thanks for the GEMS! I read just about the whole thing this afternoon then went out and cleaned my IACV. Wish I had found this info a long time ago! |
Originally Posted by Danny Lee 97 Disco
(Post 309759)
Sava,
Thanks for the GEMS! I read just about the whole thing this afternoon then went out and cleaned my IACV. |
Have anything like this for 14CUX or 13CU*? Thanks Sav
Originally Posted by Jake1996D1
(Post 309795)
Have anything like this for 14CUX or 13CUX? Thanks Sav
Originally Posted by Spike555
(Post 309799)
Pfftt... just put a carb on it and be done. :D
Just read thru the fuel injection systems manual. Covers 13cu 14cu 14cux and gems. Pretty sweet. |
I've read though that manual several years ago, the GEMS system is pretty sweet, defaults for almost everything, so if a sensor fails you can still finish your safari.
Once the mall crawler (the DII) came out defaults went away. |
see LAND ROVER
and Fuel injection and Rover 14CUX Hot Wire Mass Flow EFI: Service and Troubleshooting and cmb : 14CUX Information and the second site has a link to a copy of the 87 & up Rover 14CUX manual |
