general ultragauge question
Just got it a couple of days ago and noticed something annoying. When I am changing pages it will go down but not up. If I go to page 2 and want to go back to page 1, the up button does nothing, I have to go down through all of the pages to get back to 1. Is this normal or is mine defective?
Also, the average mpg and instant mpg and fuel level seem to be useless, I was going through the settings and it said no fuel sensor detected, is that normal on a 96 disco?
Yes. The fuel sensor in your Disco is not compatible with the ultra gauge. As for your other problem, sounds like the button is defective, it should scroll up or down.
If you guys read the directions you would see that the U-G uses the MAF, road speed, RPM, engine temp...to calculate the MPG readings.
Mine is fairly accurate in my lifetime average, it is only about ~1mpg low on the U-G when compared to the app on my phone.
U-G says 13.4, actual is 14.5.
The "miles til empty" function will not work because there is no fuel sender.
I wish we could scroll both ways, it's frustrating. I only use one page anyways
