Have to Pump the GAS pedal to start on occasion
Old Dec 28, 2010 | 12:32 PM
kosho's Avatar
Default Have to Pump the GAS pedal to start on occasion
Hello all I have a 98 Diso 1 with only 78k original miles. Everything seemed fine until recently. Most of the time it starts up right away but sometimes I try to start the car and acts like it want to turn over but doesnt then I pump on the gas and it starts. THIS HAS HAPPENED TWICE IN A WEEKS PERIOD. Anybody have any ideas why this is doing this?
Old Dec 28, 2010 | 01:53 PM
Cosmic88's Avatar
Default any other symptoms?
Does it act odd during any other time? Does it idle well when the engine is cold and hot? Does it do this when the outside temps are hot or has it only started as the weather cooled down? Does it stumble / lose power during coasting or braking?
Old Dec 28, 2010 | 05:12 PM
kosho's Avatar
Nope it sounds fine and runs fine normally. It doesnt matter if its cold or hot etc.
Old Dec 28, 2010 | 09:58 PM
COOTER-GUY's Avatar
Sounds like Fuel Temp Sensor to me "FTS" same symptoms I had till I replaced mine, when it finally starts after extended cranking it will black smoke a little with raw fuel.
Old Dec 29, 2010 | 07:41 AM
Check your fuel pressure at the rail after it has set over night and before starting. If it is low or 0 then your fuel pump valve has failed and the pump will need to be replaced.
Old Dec 29, 2010 | 05:18 PM
kosho's Avatar
Check fuel pressure at the rail? What is the rail, instrument panel?
Old Dec 29, 2010 | 07:24 PM
Look close at the pic, you will see a fuel line that runs along the middle of the intake plenum, and you will see a tire valve on it, that is the fuel rail, that tire valve is where you check the fuel pressure.
http://www.roversnorth.com/store/p-1...-manifold.aspx
alias_J
Jan 28, 2011 02:36 PM
RROJ
Aug 20, 2010 10:07 AM
LANDZUII
Jul 19, 2009 02:04 PM
ljdiscovery
Feb 15, 2009 08:56 PM
Skunky
Jan 31, 2008 10:20 AM
