HELP! Driver's Door frozen shut!
So I left work and was able to open my door fine but it took a few tries to get it to stay shut. So when I got home, I drive opening it and neither the interior nor exterior handle felt like it was attached to anything. Didn't make a difference if I had the door locked or not. Climbed out the window that was fun
I tried locking and unlocking it from the key and still nothing. All other doors open and close no problem.
What to do to fix?
Thanks!
What to do to fix?
Thanks!
I realize you would have to climb over the center console but then at least your window would be up and I think that would be easier than climbing out the window.
You need to remove the interior door panel to get the door open.
There are screws that hold the pull bar on, remove those, you can then pry back the panel and reach the door latch and pull it with needle nose pliers.
Then once the door is open you can remove the panel the rest of the way.
Happens to me all the time now because of the weather, I hold the hand open and lean backwards on my heels. I think it's because the seals on the door that are supposed to keep the inclement weather out get stuck against the metal. Something along those lines. Bottom line, pull the handle out and lean backwards like you are trying to pull the door out and the handle is your only..well handle. Tell me how that goes
