Help! Stripped nuts and bolts removal...
Any one have a trick to remove stripped nuts and bolts from TC side of front Axel? Cutting wheel and grinder I have is too big to get at them...
https://cimg8.ibsrv.net/gimg/landrov...ea93391df1.jpg TC side of front shaft... |
Cut the bolt head side. Rotate the shaft for access. Should be plenty of room for a sawzall or dremel wheel.
If it's too tight for a sawzall or dremel, use a chisel and hammer. Once you get the nut turning it will back out pretty easy.
A shaped explosive charge. Make sure you only use a wee bit.
Plasma torch!!!!
Ferengi energy whip!
Fuel leak, bad starter connection, and a paid to date good homeowners policy or auto policy if you chose not to park next to dwelling.....
