Help and Suggestions?
I just got a 97 Land Rover used with 145k in Feb. its been running great since I got it, but this morning I was a mile away from the house and Land Rover SE 4.6 97, got where it would only get up to 10 mph and that was it. Any ideas on what might be wrong, the check engine light is not on yet. If I give it full throttle it will still only go 10 mph tops.
Thanks for any suggestions and inputs..
Primey
Thanks for any suggestions and inputs..Primey
First off, it should be a 4.0 V8 engine, unless it has been replaced. First thing I would check would be the fuel pressure. You may have a clogged fuel filter, or a fuel pump that is ready to give it up. The fuel filter is inside the right rear wheel well. It can be a little tricky due to corrosion, and watch out for the little o-rings that seal it to the fuel lines.
Whenever you encounter any such degradation in performance, unusual noises, or other odd behavior, you should immediately stop in the first safe place and do aa good walk-around look-see for out of the ordinary things.
This is one of trhe funniest threads I have seen yet as far as way something went wrong. If a stick that small slowed you down that much............
Welcome to the Womderfull World Of Discovery.
You didnt see the stick before you ran it over?
If it was lodged between a wheel and the ground it would have provided some serious dragging resistance.
Imagine how long it was before you stopped.
Being a Novice I figure it pinched the fuel line or something or blocked some sensor. Thanks for your help and I just wanted to report my findings.
