High Idle
I'm trying to get this high idle figured out. It's not as high as many have described (1500-2000), but more in the 12-1300 range most of the time. It drops down when I put it in drive to normal idle (700 I've been told?), and it also drops by about 100 rpms when I turn on the a/c. I've been told that if the idle drops when you turn the a/c on it's probably an issue with the Idle air control valve, but I don't want to go spend money on the part if it's not the issue. also, will I need to reset the ECU after installing the new iacv if i do to fix the idle issue? I have also heard that that is necessary
Yeah that's what I'm having issues with. I'm not the best with diagnosing these things. I believe from what i've heard it's role is in the vehicle (higher idle on cold start, and raising the idle when the a/c is engaged) is making me think that it's the IACV, and that part is only like 40, so I may just try that and see if anything changes
Remove IACV clean it and the throttle body, check the valve cover pcv hoses, clean the pcv noodle in pass valve cover, check vacuum line for the fuel pressure regulator
Everything's probly filthy if you have not done these
Do you have codes?
Do you have codes?
Okay I have not done these yet, but I should be getting to them soon. And I believe I have one code, I can't remember the number, but it was something to do with the 02 sensor (I believe to be because my cats were deleted previous to me owning it and nothing was done with them).
So I know this thread has been pretty dead, but now I am having a different issue that I'm not sure is related. Now when starting it in the cold (Here in Illinois it's almost down to 0F), it idles very low and sputters like it's going to die. People think I just need to clean the MAF sensor?
Do you know your fuel pressure when running? This is a temp fix, leave the key turned on but don't start the motor until the pump shuts off. Might take two times to get the fuel pressure up high enough to keep the motor running. The other temp is to use your foot on the gas pedal to get it to idle long and smooth enough to remove your foot and let the IACV control idle. You need an ECU reset......
