Hood / Bonnet stay grommet replacement
Hi,
I have two D1's and a Disco II that require replacing the Bonnet stay grommet (a.k.a., the hood grommet for the hood arm). I have found part number 369746 but what puzzles me is that it states that this is for a Disco II. I would wager a guess this is the same part for the D1? If there is a different part number for the D1, would someone be so kind as to share it? :cheers: |
DI > # AYA10004L but the 369746 will work.
Just a heads-up, you can find a similar prop rod grommet ( IDK the part # ) in the "HELP Section" at AutoZone, Advance, NAPA. :cheers: > https://parts.landrovercary.com/oem-...bC12OC1nYXM%3D You can see it here... > https://www.ebay.com/itm/LAND-ROVER-...wAAOSwWxNYvwew |
Well what do you know, I'm missing that do-dad as well. Didn't know it was something to be missed until I read this thread. :dunno:
Now my ch'i is askew. :cry: |
Originally Posted by hrhoward
(Post 691522)
now my ch'i is askew. :cry:
I looked this weekend. Apparently my ch'i is fouled up as well.
Some aroma therapy might help.
Too bad my p.s. fluid isn't leaking on anything that gets hot. |
(Post 691423)
Found the dealer had three of the Discovery II grommets for cheap... They fit a discovery II perfectly, but are a little oddly shaped for the Discovery I; however, they work :)
Thanks everyone! |
Would you mind providing the part number for the grommet you found?
Originally Posted by vegas99d1
(Post 698436)
would you mind providing the part number for the grommet you found?
