Hood / Bonnet stay grommet replacement
Hi,
I have two D1's and a Disco II that require replacing the Bonnet stay grommet (a.k.a., the hood grommet for the hood arm).
I have found part number 369746 but what puzzles me is that it states that this is for a Disco II.
I would wager a guess this is the same part for the D1? If there is a different part number for the D1, would someone be so kind as to share it?
DI > # AYA10004L but the 369746 will work.
Just a heads-up, you can find a similar prop rod grommet ( IDK the part # ) in the "HELP Section" at AutoZone, Advance, NAPA.
> https://parts.landrovercary.com/oem-...bC12OC1nYXM%3D
You can see it here...
> https://www.ebay.com/itm/LAND-ROVER-...wAAOSwWxNYvwew
Found the dealer had three of the Discovery II grommets for cheap... They fit a discovery II perfectly, but are a little oddly shaped for the Discovery I; however, they work
Thanks everyone!
Thanks everyone!
