Instrument cluster compatibility
Old Jul 7, 2012 | 03:21 PM
sdyver's Avatar
6th Gear
Default Instrument cluster compatibility
I have a UK (left hand drive) '97 Disco I and the tach doesn't work. My speedo only has km/h. If I install a US spec instrument cluster with mph speedo, will the speedo work and do they use the same connectors? Thanks.
Old Jul 7, 2012 | 03:32 PM
If your tach does not work that usually means that your alternator is dead.
Yes, a NAS unit should work.
Old Jul 7, 2012 | 11:15 PM
oilspotLR's Avatar
Yes a NAS unit should work, also, there are different connectors in LR's under the instrument cluster. Not sure why. Maybe UK uses different connectors? Either way it should work.
blackcatphil
Jul 2, 2014 05:11 PM
riko suave
Mar 18, 2009 04:34 PM
CandiMan
Oct 30, 2008 01:39 AM
coldfrez
Oct 1, 2007 09:49 AM
Greg
Aug 8, 2007 04:47 AM
