Kendall GT1 Oils..OUR TICKET
It is a 10 weight oil with polymers added to keep the oil from thinning too much when it warms up. And the polymers start to act at about 100*, so having a thinner oil base in a hotter environment is not necessarily a good thing. It causes the polymers to break down quicker and requires more frequent oil changes. An oil that starts life as a higher weight will generally have fewer polymers than an oil that starts life as a lighter weight oil.
As for zinc, it is only used to protect metal to metal wear. If you are having metal to metal wear, then the oil you are using is failing you. Change it. The oil is supposed to protect from metal to metal. Either the oil is not being changed enough, or it is the wrong multi-grade for your driving conditions.
So is a higher zinc content good for your engine. Sure it is, if you don't change your oil at regular intervals and use the incorrect multi-viscosity oil.
Well, I looked up the specs and see nowhere where it claims to be a 45 weight or even anything other than a 40 weight with the help of additives.
The bigger the difference between the bottom and top numbers the more work that oil has to do.
I did a experiment with my old work van one summer.
5,000 mile oil changes at a quick lube.
E-250 with over 200,000 hard miles on it, 5.4L Trition V8.
5w-30, 3-4 qts used per week. (1,000 miles a week average)
10w-30, 2-3 qts per wk.
10w-40, 2-3 qts per wk.
15w-40 diesel oil, 2-3 qts every oil change!
HUGE difference between oil weights.
New Rotella T does not have a good amount of Zinc in it due to new diesel regulations and newer engine designs to cope with such changes...Shell wont release specs on the oil either...I do not think...i think they are reduced to passenger car quantities (low low low)
Here is a quick google search I did....Shell Rotella T
Pretty much if you can find it in CI-4 rating than your ok with it but almost all major chains have the new CJ-4
In our old engine design..we need ZDDP
TRIARII
05-23-2015 04:31 PM
