Land Rover Radio code
Picked up a '98 Disco1 and it has had alarm issues. I have it running and it needs a bit of attention. The radio comes up with a simple message on the screen "CODE" and then shuts off after a bit. No sound or anything. Anyone have a clue of a generic code that might work?
I know I could pull the radio and use an aftermarket one but I thought I'd give this a try first.
There is no generic code. look through the owners manual for the code it is on a laminated business card. If no luck pull the radio, the PO may have written it on the case. After that its a call to the dealer or replace.
I'll give that a try. My other D1 did not have a radio, just a hole in the dash where it was supposed to be. Got a $50 Walmart unit that has worked well for the last 7 years now.
PO wrote code in owner's manual under radio section. I also found it on bottom of coin tray on dash. Written in black ink so I had to hold it just right to see it.
No owners manual. Code was on steady and I punched in the serial number. Now it is flashing when I turn it on. Did I start up the timer??
On the plus side, the CD changer under the pass seat ejects the cassette for the CD's and makes noise when I put it back in place. sounds like it might work.
its got to be on for over an hour before itll clear out and accept a code again
the serial # is not the code. Im surprised yours doesnt have 7,8,9, or 0 in it. You need to have the dealer look up the code using the serial #
Left ignition on Acc for over 1 1/2 hours with a charger on the battery, still a flashing code on radio, turning key off and on didn't change anything. Still no code as the dealer has not called back with a code. Maybe time to visit Wallyworld and buy an aftermarket radio. unless anyone has an idea ... Thanks for all the help! You guys have bailed me out many times!!
