leaning to left?
Old Aug 19, 2013 | 06:10 PM
dansgt's Avatar
Default leaning to left?
So when I bought my truck it was leaning to the right a bit. Figured it was the shot suspension, however couple busy months ago I replaced the shocks and springs and it made no difference. Used brand new Terra firma parts and they were installed properly, and I didn't see anything damaged when I did the work. Any ideas? Lift was even all around, just left the lean, bout it 1" to the right.
Old Aug 20, 2013 | 07:10 AM
robertmirwin's Avatar
Are any of your mounting location bent or out of spec? maybe a stupid question but are all of your tires the same size?
good luck
Old Aug 20, 2013 | 08:06 AM
dusty1's Avatar
how much of a lean. I have 3/16" high on front driver side. but it is gone when i put my big butt in the seat.
Old Aug 20, 2013 | 01:10 PM
dansgt's Avatar
Like I said about 1" to the right, measuring top of tire to bottom of fender. All mounts looked fine, all tires the same. Only thing I can think is one side the body mounts are bad? Was parked a few years before I bought it in the California sun...
Old Aug 20, 2013 | 02:40 PM
dusty1's Avatar
try putting one of these on it.
Old Aug 20, 2013 | 02:41 PM
dusty1's Avatar
are your isolators in place?
Old Aug 21, 2013 | 06:19 PM
dansgt's Avatar
Isolaters in place in the rear, there's nothing up front, same side to side.
Old Aug 21, 2013 | 06:38 PM
dusty1's Avatar
gotta be body mounts, then. nothing bent, all in place, same components left to right......nothing else in there. I think your right, it was just how it was stored....sun and weight to one side, perhaps.
Old Aug 21, 2013 | 07:10 PM
fishEH's Avatar
You know the TF springs are side specific right? I'm sure you installed them correctly but I figured I'd mention it anyways. My truck leans passenger side since I bought it. The body mounts all look ok so I just threw a short spacer under the rear passenger spring. Leveled it right out.
Old Aug 21, 2013 | 07:15 PM
dusty1's Avatar
seriously? side specific? I for one had no idea..good to know, I guess I got lucky, in the order. btw are ome side specific too? tf now but my last lift was ome and I had to space it too level.
