Lift question
I've decided it's time for a new set of springs as the rear is no longer sitting level from side to side. In doing some searches, it seems the best avenue is to throw a set of 2" after market springs from either OME or Terrafirma. Now in reading, I see the opinion between which is better is pretty much split so, its all about price I guess. However, what I'm not finding a whole lot of information on is whether the larger investment of "reclocked" radius arms are required front & rear to avoid any drivability issues. My driving habits are lots of miles (over 100 a day) on country roads & highways with occasional minor off road use. Any advice?
I have the 2" one HD set and all I did is remove the front swaybar, have driven back and forth from n.j. to VA, only thing is the vehicle is top heavy so I do notice little more sway on highway, definitely would not go with Med or light springs they would probly make the sway worse for onroad imo
Remember
OME Med = TF Light
OME HD = TF Med
OME Extra HD = TF HD
TF HD will be very firm, harsh, and articulate less, but it will sway less on-road. Pick your compromise.
Air suspension and sway disconnects allow you to have it all, but the compromise then becomes complexity.
OME Med = TF Light
OME HD = TF Med
3" lift, no sways, 33" MTs, stock radius arms....70mph all day! I have a plan in the works to cut, bend, and plate some spare radius arms I have to bring my pinion back about 3-4* and reduce frame end bushing bind but it drives OK on stockers.
Remember
OME Med = TF Light
OME HD = TF Med
OME Med = TF Light
OME HD = TF Med
