-   Discovery I (https://landroverforums.com/forum/discovery-i-39/)
-   -   Lift and tire question (https://landroverforums.com/forum/discovery-i-39/lift-tire-question-50768/)
Discolife Jun 28, 2012 12:05 PM
I recently purchased 4 blocks that will give me a possible two inch lift.........I do enjoy the stock spring rates and hope the vehicle will get a nice lift while retaining the ride quality.
Is spring lift better?
What size tire are you guys running on stock wheels?
Jake1996D1 Jun 28, 2012 12:21 PM
It's all a matter of what you're trying to accomplish
Are you going to remove your sway bars?
You can get away with a 2" spacer lift with sway bars however if you take the sways off I would recommend a set of coils with heavier rating to help with body roll.
Shocks - you will likely want to get some longer shocks as well. Terrafirma makes a good cheap kit with shocks and springs. Justin at L8 has good prices on it all.
With bigger tires it is always recommened to regear. Rule of thumb is 4.11's for 32's/33's 35's run best at 4.37's. You can get away with stock gearing for 32's and 33's but it's gonna be a dog. 35's would suck on stock gears and will eat stock diffs and axles.
235/85/16 Skinny 32" very minor trimming is needed for these two
265/75/16 Wide 32"
255/85/16 Skinny 33" a little trimming it needed for the skinny
285/75/16 Wide 33" more timming or lift is needed for the wide
315/75/16 Wide 35" - I' know guys who run this size on stock rover wheels but it's a little wide for most peoples comfort. - gonna need to trim a lot and gonna want 3" + of lift
Biggest benefit of rover wheels is they seal a bead pretty damn well.
Discolife Jun 28, 2012 12:33 PM
jake, its my wifes daily driver and she loves the rugged look. for offroad use its only sand and desert.
For her safety and that of our new daughter I would say the sway bars stay.
I think what she would like is a 2 inch lift and more agressive LOOKING tires, ie wider for sure, maybe taller....
Jake1996D1 Jun 28, 2012 12:36 PM
245/75/16 BFG AT otherwise she will complain it's slow and loud :D
Keep the sways add the spacers and see how it feels on the road. However I can tell you there is nothing like new springs and shocks on one of these trucks.
Discolife Jun 28, 2012 12:39 PM
Well the shocks are new, as are the slotted and drilled rotors, new calipers etc. all suspensions bushings done about 2 years ago or less.
Thank you for the advice. Its currently running on new mich snow tires. siped etc. man it grips well in the rain.
Stock tire size on it now, how wide are the rims?
Jake1996D1 Jun 28, 2012 12:44 PM
Stock rims are 7" wide
Only issue with wider tires is that you lose turning radius. It's not terrible with 245's just something to keep in mind.
fishEH Jun 28, 2012 01:08 PM
235/85/16. Nice and narrow to keep your turning radius and tall to fill the wheel well nicely. Might need a very slight Camel Cut just behind the front tires. If done well it will look sano. ;)
Jake1996D1 Jun 28, 2012 01:14 PM
You're on a "sano" kick lately huh?
pinkytoe69 Jun 28, 2012 01:15 PM
Yeah, but his wife doesnt want the pizza-cutter look...she wants beefy :)
fishEH Jun 28, 2012 01:28 PM
They're not that bad. They actually look pretty good. My buddy just put 235/85/16 Goodyear DuraTracs on his D1 and they look really good. Its the one on the ramps in this pic. His front bumper is slightly tweaked, normally the plastic wouldn't be that close.
http://img.photobucket.com/albums/v6...2/P1350366.jpg
Jake, Sano is a sweet word that is grossly under-utilized. ;)
