Muffler Replacement and Exhaust Repair
i actually found them on ebay.....need to make sure it is a "teeth" version...thanks for pointing that out!
Haha, I dunno if "teeth" is the right word. The grabbing mechanism is basically a drill chuck, but each of the 3 grabbers have teeth instead of being a solid triangular shape. If you get that Titan one youll see what I mean.
This is what it looks like when fully extended. Basically, unscrew until the grabbers can just get onto the stud, then make sure you get it all the way down to the base of the stud before you proceed with clamping/extracting.
You can try a screw type extractor. They work for "household" level stuck screws. Failed miserably on my manifold stud...maybe I used it wrong?
Or is there something specific you wanted pics of?
