Mystery seal in my swivel ball kit
Refurbing swivel *****, and I got the kit from AB. Included is a seal that I can't identify, man I have no idea what it is for. Here are some pics:
![Name: tDhKbl.jpg
Size: 59.7 KB](https://landroverforums.com/forum/attachments/discovery-i-39/57422d1683051325-mystery-seal-my-swivel-ball-kit-tdhkbl.jpg)
it is marked "IN53275", "51" and "CFW" on the outside. What is strange about it is that it has a metal insert type thing in the back, like a slightly smaller seal was pushed into the back of it:
![Name: SkAztl.jpg
Size: 52.4 KB](https://landroverforums.com/forum/attachments/discovery-i-39/57423d1683051325-mystery-seal-my-swivel-ball-kit-skaztl.jpg)
It is too small in diameter OD-wise to fit anywhere from the drive member all the way along the axles to the casting, including inside the stub axle, but the ID is right for passing the axle.
Any ideas? Is it extra? Extra parts always stink of incompetence, aside from making me nervous.
TIA -
geek
![Name: tDhKbl.jpg
![Name: SkAztl.jpg
TIA -
geek
Naw, it was just in a bag in the box with the rest of the stuff. No markings. And the kit doesn't have a manifest listed on the website, either. I don't want to wait until monday either *sigh*. And I don't think it is a mistake, as I bought two kits and there is one in each kit. Nothing like it, however, has emerged from the teardown of my front end.
No, originally I thought it went in the stub axle but it is too small, I found that one by looking up the part number to be sure. It is about !/4" smaller in diameter than the needle bearing. And the metal piece definitely doesn't come out, it is made that way.
Here is a picture of everything laid out:
![Name: SMUbsl.jpg
Size: 83.8 KB](https://landroverforums.com/forum/attachments/discovery-i-39/57421d1683051325-mystery-seal-my-swivel-ball-kit-smubsl.jpg)
bottom to top:
joint washer
inner swivel ball seal
large swivel ball seal/wiper and retaining plate
swivel ball
lower conical swivel pin bearing
swivel ball housing and dust shield
joint washer
refurbed stub axle - new seal, bearing and thrust ring inside
mystery seal to the right of stub axle
hub seal and joint washer
hub and bearings
rotor, washer stack and SLEDGE HAMMER, MVT on this job
red high speed kryloned caliper
drive member
EBC Green Stuff Pads (Do these suck? I hope they don't suck, they were pricey. I think I read some posts that said they suck. I hope they don't suck.)
Don't think I left anything out...
![Name: SMUbsl.jpg
bottom to top:
joint washer
swivel ball
joint washer
hub and bearings
drive member
Yes you did.
Beer.
Beer.
