Need inner pass side kick panel pic
Can someone remove their passenger side kick panel and take a pic? Need to see how the relays are supposed to be laid out. Mine is just all stuffed in there :/
1 Attachment(s)
There is a download that is free.
It is called the RAVE (Rover Automated Viewing Environment). It contains the electrical drawings, connector pin outs, color codes. It also includes detailed photographs of the device locations. Once downloaded, it will provide endless hours of enchantment and become your favorite Brit Lit. Even at 3:37 AM. A sample is attached. You will note that unlike photos posted by members, it includes details of which connector and relay and such so you will know what you are looking at. The RAVE for the D2 is in color. If you can't download the whole RAVE, sections are also available in a link below. |
Its not so much the connectors or wiring, as much as it just the layout. Need to see how everyones disco has the wires routed and relays mounted, so I can put mine back together how it came from the factory.
Ill take a pic tomorrow and post it to better illustrate my point |
1 Attachment(s)
here tiz
Note: I just got to your other post with the "I asked for a pic from behind someones pass. side kick panel not a finger towards the RAVE manual. "
Enjoy your continued search for the solution. If you are not an experienced electrical person, this may not be the type of repair to conduct DIY, in particular if you don't like assistance that is offered. |
